Gradient Section View Depth Labels
mihailo_jovanovic9UASP
Hello everyone,
I am new to Civil 3D, so can anyone tell me how to remove, or just make smaller arrows on Gradient Section View Depth Labels? (image attached below)
ianjchap
Hi @mihailo_jovanovic9UASP,
Select the arrow label, right click and select Edit Label Style. Then hit the triangle next to the Edit pencil to edit the Current Selection.
There, change the component name to the Direction Arrow. Then you'll have a minimum length that you can reduce. Ithink that should do it.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
ianjchap
Just an after thought, it may depend how that label has been added.
Is it part of a label group on the VP? or a single label?
I can actually grip edit and change the length of my label to whatever I want (given the right annotation scale).
However this might be different for some labels applied as a label group.
And just realised you have a section rather than a Profile View. But same applys to Section Views, you should be able to grip and adjust for individual labels.
Ian Chapman
