Ok I have approx. 150 cross sections and need to change the color of the line work for the corridor sections. I am using the "Code with Labels" style. I have been digging for the last couple of hours and can not find where to change the color of the line work.
I have done this before in a previous project and have it set up the way I want it, but apparently you can not copy code styles from one project to another. I tried
Any help would be greatly appreciated.
C3d 2018.2 in use
Dave Z.
Solved by Jeff_M. Go to Solution.
You can drag n drop code set styles from drawing to drawing or use Import Style and Settings (Manage Tab).
You will want to edit the Link Styles within the Code Set Style. It is important that you know which Links your Subassemblies use.
I have tried dragging and dropping it won't do it. Also get seam to get the import code style to work. Unless I am doing sumptin wrong.
Make sure you drag in any Link, Marker, and Shape codes used by the CodeSet, then drag the CodeSetStyle.
To Drag, make sure both drawings are open, with the Target drawing the active one. In Toolspace, Settings, makes sure the top option is set to Master View, then scroll to the Source drawing and find the Object to copy, select it and drag it into the drawing canvas of the Target drawing.
Hi @Anonymous / Dave,
I know you don't like videos without CC so I will post an image guides instead. Things you need to watch out would be draw order of Link codes and surface on top of corridor links. Guide images below will show step by step.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Thanks guys. I have the colors changed on all the codes. The Code link was the key. All though I was doing it right, it turns out there are other lines overriding the ones I modified.
I also have this fixed in my template file and typed out some notes
