get the coordinates of the points From longitudinal profile
Oliver_C3D
Oliver_C3D
How can I get the coordinates of the points that participated in the construction of the longitudinal profile?
Jeew-m
You can use Incremental Station Elevation Difference Report from report manager.
For this you need a design profile and a existing ground profile.
Make sure you set the parameters properly.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Oliver_C3D
The locations of the points that participated in the construction of the longitudinal profile are irregular. And I just want to get the coordinates from these output points!
Jeew-m
Then you can use this method.
According to the image the red vertical lines are profile geometry points.
You can create points on profile geometry points.
I think that is what you need.
If you can attach a dwg with some more explanation we can help further.
Jeewana Meegahage
Design Engineer
Oliver_C3D
I need a simple, low-time way
Jowenn.Lua
Hi @s.oliver92 ,
I believe you want to create a report that will give easting northing elevation of each PVI in the profile.
Please see <screencast> below as a guide. Also see attached Sample_CivilReport.XLS report.
Cheers,
Jowenn
Oliver_C3D
It was great !
That was exactly what I wanted.
@Jowenn.Lua
