Hello, I am using the geotechnical module in Civil 3d 2020. After setting the 3D Exaggeration to "1", the borehole models are presented with the correct ground level and depth. How can the diameter of the models be changed? Currently it is about 14m. I found a setting to make the location point thinner. Is there a similar setting for the 3D model?
Greetings from Germany,
Micha
