Hi All,
I want to secure some of my sub-assemblies so that it become non editable .
Can anyone please help me in this regard.
Solved by Jowennl. Go to Solution.
Hi @ansarimdnazir ,
Pkt is meant to be saved in a secured server and IT can provide user access to be read and write for Civil 3d admin and read only for team members. No direct way to stop people from editing it so best is to save a back up copy somewhere that you can get anytime you need. If you want extra security you can select the file and make it as read only.
I normally only share my imported tools and xtp to team members so that we are all sync. Then I can hide the pkt to avoid editing. Of course people can be smart to convert all the imported tools back to PKT but that is another story.
Try to watch my Au Class in 2017, I gave tips on how to share customised assembly to team members. Click my profile and find my AU class.
Hope that helps.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Make a fence sub to go around them
Joe Bouza
Just adjust the permissions on the pkt file to read-only for everyone except for the editor (probably you). Most likely you will have to ask IT to do this.
If you would rather not get IT involved you could keep a zipped copy... password protect the zip.
Hello @ansarimdnazir , welcome to Autodesk Community!
Did any of the above suggestions help solve your problem? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Hi Jowenn.
First of all I would like to thank for your quick reply.
I got sample PKT file Thanks once again for sharing this.
