Hello
could you help me, in telling me
If I can edit the diameter of the cylinder that simulates being the hole.
within the geotechnical module.
Thank you
Yes you can by going into Styles
Ensure Geology code is selected
Under 3D stick, create a new sun style and set size to 1 or 2
then press set current, and that should do it
