Geotechnical Module 2020-2021: Installation failed (Fatal error)
olubunmi.oluwole
Message 1 of 9
olubunmi.oluwole
Installation of C3D_20ExtGeotechnicalModule.exe (run as administrator) failed (with Fatal error). The log file is attached. What could be the cause of the failure?
Replies (8)
Message 2 of 9
abd_eng_001
Same issue here with update of GeotechnicalModeler.exe under Civil 3D 2022 with AEC license.
Message 3 of 9
jaanYPY4L
Geotechnical modeler installation failed - Autodesk Community - Civil 3D
Created this topic yesterday, glad im not the only one experiencing this issue. But it seems for some people it is working correctly.
Message 4 of 9
abd_eng_001
I tired to update from the Autodesk Desktop App and manual update file download from Autodesk website. Neither of them worked. Couple of restarts also not worked. Waiting patiently for a solution...
Message 5 of 9
GavinHarper1
Indeed, announced with much fanfare and then the download won't install. Won't get many attendees at the webinar at this rate
Message 6 of 9
olubunmi.oluwole
Geotechnical Modeler 2022 was installed successfully and works Civil 3D 2022.1.2
Message 7 of 9
abd_eng_001
Civil 3D I have is also 2022.1.2, but unfortunatelly up to date I still can not install, the same error I've shared before comes up always.
Message 8 of 9
olubunmi.oluwole
In an attempt to install Geotechnical Modeler 2022, we got the attached error. Does anyone know what could be responsible for this?
Message 9 of 9
abd_eng_001
I have the same error since this module visible in Autodesk Desktop App. Unfortunatelly, no one has come up with a solution.
