Geotechnical Module 2016 Database
Message 1 of 9
Hello all,
I am trying to share a geotechnical module 2016 database with someone else on a different computer. Where is the database automatically saved by the module? The files found here: "C:\Program Files\Autodesk\ApplicationPlugins\AutodeskGeotechnicalModule2016.bundle\Contents\Databases" say that they haven't been modified since 5/14/15, but we modified the database today (10/2/15)!
Has anyone encountered the problem of not being able access a database that was created on someone else's computer?
Replies (8)
Message 2 of 9
neilyj666
This is my understanding of the database location for 2016.....mine also has the last modified date as 14/05/15; must be the  way it is...!!!
Did you try the database on another user's machine?
2015-10-02 19_10_42-C__Program Files_Autodesk_ApplicationPlugins_AutodeskGeotechnicalModule2016.bund.jpg
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 9
Hi
The geotechnical module is designed to use the local database, it is normally installed here C:\Users\"youlr login"\AppData\Local\Microsoft\Microsoft SQL Server Local DB\Instances\Geotechnical Module.
However if you want to have a shared database I would recommend using HoleBASE SI, geotechnical modules on different machines then link into the same data.
Regards
Gary
Message 4 of 9
neilyj666
That's interesting @Anonymous as I was advised by Keynetix support that this was the location when I enquired about backing the database up.
Is the folder that you have identified the one that needs to be backed up or is it as I had been advised?
Message 5 of 9
Hi Neil
You will need to back up the one I've said
%localappdata%\Microsoft\Microsoft SQL Server Local DB\Instances\Geotechnical Module
The files in the autodesk bundle folder are just the orginas, they are copied and updated in the foldr above.
Regards
Gary
Message 6 of 9
neilyj666
Excellent - many thanks for clarifying
Message 7 of 9
We tried copying the files and replacing the ones on the other computer but it didn't seem to work.
Message 8 of 9
That's what I'll do! Thank you.
Message 9 of 9
Hi Gary,
it helped me a lot to find the database location, but still in my new profile it has username and password issue and I can't establish new connection too.
can you please help me with this too?.
regards,
Ali
@Anonymouswrote:
Hi
Regards
Gary
