Geotechnical Modeler Moduler Adding project Problem
mustafasekman
mustafasekman
Community Visitor
Community Visitor
i have donwload and install the geotechnical modeler module. i have watched the webinar performed in 23.02.2022. but i cannot add any borehole data. Instead adding the new project or new borehole data i have get the error given below. Please say me what can i do for the fixing these conditions.
Error Message...
constraint failed
UNIQUE constraint failed: Project.Id
Error Details...
code = Constraint (19), message = System.Data.SQLite.SQLiteException (0x800027AF): constraint failed
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at Dapper.SqlMapper.ExecuteReaderWithFlagsFallback(IDbCommand cmd, Boolean wasClosed, CommandBehavior behavior)
at Dapper.SqlMapper.QueryMultipleImpl(IDbConnection cnn, CommandDefinition& command)
at Dapper.SqlMapper.QueryMultiple(IDbConnection cnn, String sql, Object param, IDbTransaction transaction, Nullable`1 commandTimeout, Nullable`1 commandType)
at SQLiteAdapter.Insert(IDbConnection connection, IDbTransaction transaction, Nullable`1 commandTimeout, String tableName, String columnList, String parameterList, IEnumerable`1 keyProperties, Object entityToInsert)
at Dapper.Contrib.Extensions.SqlMapperExtensions.Insert[T](IDbConnection connection, T entityToInsert, IDbTransaction transaction, Nullable`1 commandTimeout)
at Aecc.Gtm.DomainPersistence.AGMBoringRepository.InsertProject(String projectId, String projectName, String projectLocation)
at Aecc.Gtm.AutoCADPlugin.ManageData.ManageDataPresenter.OnSelectedProjectChanged()
Elina.P
Autodesk Support
Autodesk Support
Hi @mustafasekman!
Here is the link to Geotechnical Moduler HelpPage -> you can try to find the information about fixing your problem there.
Elina P.
Technical Support Specialist
Civil Engineering Solutions
