Geotechnical modeler installation failed
jaanYPY4L
Message 1 of 16
jaanYPY4L
Hi
Is anyone else having troubles installing the new Geotechnical Modeler 2022?
Replies (15)
Message 2 of 16
DarrenP
no
i downloaded from my Account & installed i didn't use the desktop app
DarrenP
Message 3 of 16
jaanYPY4L
Downloaded it from there too and same error...
Message 4 of 16
cjohnstonJQ8JG
I received the same error trying to install this module through both methods.
Message 5 of 16
aaron.hansen
Observer
Observer
On my laptop I'm having this same issue.  Seems to be fine on my work PC?
Message 6 of 16
DBreisch
Still cannot install this.
Side note, is there any way to remove this from the App so I just don't see the update? I don't even want it, just want it cleared from my list (yeah yeah I know).
Message 7 of 16
Elina.P
Autodesk Support
Autodesk Support
Hi All!
Try to use the workflow described here, which includes the extension installer.
Elina P.
Technical Support Specialist
Civil Engineering Solutions
Message 8 of 16
atrealt
The link you provided is not working for users unregistered at wiki.autodesk.com which seems to be only for autodesk empoyers.
Message 9 of 16
Elina.P
Autodesk Support
Autodesk Support
You're right, I will look for the source which is open for you.
In the meantime, try to download it through your Autodesk Account instead of the Desktop App.
Elina P.
Message 10 of 16
DBreisch
"..try to download it through your Autodesk Account instead of the Desktop App." Then what's the point of having the app? Appreciate the help but too many things from AutoDesk are workarounds versus fixing problems.
Message 11 of 16
atrealt
As previously mentioned it does not work as well. It gives the same error. I expected more sophisticated solution like registry edit etc. There is some problem with installation of this extension itself. My context is Windows 11 with all current updates and Civil 3d 2022 edition with all current updates. The downloaded extension is 2022 edition respectively too. All other updates were applied with no issues.
Message 12 of 16
jaanYPY4L
Any progress? If there is a workflow and an installer, just share it here.
Message 13 of 16
654work
What's the status of the fix?  We are having the same problem with the install.  Have tried the install with the Desktop App and downloading the file, both failed.
C3D 2022, latest updates
WIN 10
Message 14 of 16
jaanYPY4L
Actually got it installed. No fix, i just updated the regular AutoCAD 2022 and i think the licensing thing too to the latest version, and then it just worked. Apparently just having your Civil 3D up to date isnt enough.
Message 15 of 16
DBreisch
This should not be marked as a solution because it worked for one person. The installation still fails.
Message 16 of 16
zrobinsonBXDV5
I don't know if anyone is still having problems with this, but I found that the link below has an update to the Autodesk Installation Service (the  AdODIS-installer.exe file) that FINALLY made the geotech modeler update. I had to download this in order to update the Civil 3D 2022.2 update and surprisingly it worked. The steps are about halfway down the page.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/A-requ...
