Our users are taking advantage of GEOPDF's that they download USGS for Aerials in our design files. When they are XREF'd into a drawing, then a Clipping Boundary is added to show just what the user want to see, they look awesome, level of detail etc... but the performance of our Civil goes in the tank. I can unload them when designing and performance returns, but kinda of defeats the purpose of using them as reference. I have tried the ImageQuality variable changing to Draft, but doesn't improve performance. I have also tried using PDFIMPORT Underlay on the XREF'd PDF to get just the information I want, but it seems to lump everything onto specific layers and I really have issues navigating and getting the look I want. Is there a better workflow for using these types of files in Civil 3D? I watched a video on how to use PDFIMPORT and looked awesome but the PDF was originally created using AutoCAD and so things went much smoother then when I tried with the Aerial PDF, plus the tiling together of multiple (4).
Hi @Anonymous,
How big are the files that you're trying to use? The behavior you're describing normally occurs if you're attaching a big file to your DWG.
They can vary, but for this drawing we have 4 PDF aerials stitched together ranging from 12,988KB to 15,455KB. Sometimes they can be up to 48MB in size for just one.
@Mike_Hurtado wrote:
Hi @Anonymous,
The size might be an issue, especially when you start to have multiple in the same drawing. Can you try a different file format such as a TIF perhaps?
Yes we could and do have tiff and SID that we use, but I am trying to accommodate our PE's as they use the PDF's from the USGS site.
You can try to make an FDO connection to the PDFs in the Planning and Analysis toolspace. If the performance is bad there as well I would start looking into using those TIFF or SID formats. PDFs do tend to slow things down in Civil.
Hi @Anonymous,
Wanted to check in to see how things were going. Did you figure out a way to improve performance with the files in Civil 3D?
No still an issue when we have several in a drawing at one time. I tried to use as an Overlay then run PDFIMPORT to just bring in and crop what we want, but results weren't what I expected. Still searching for best practices on using PDF files as Aerials and the GEOPDF files.
