Geometric center of objects not accurate????
aaron_cotney
Message 1 of 36
aaron_cotney
Hi, im just having a tiny problem thats playing havoc with me at the moment. Im use to working with cad lt but company have just recently aquired civil 3d.
My problem is when i draw a rectangle and i try either rotate or move it by the center point grip, the center grip is not accurate, either slighty off center or outside of the rectangle entirely???? Also when i try to draw a small rectangle the geometric center grip just doesnt display??? All works fine on cadlt for some reason,,, help,,, driving me insane. All my osnap settings are the same as i have in cad lt too.
Replies (35)
Message 21 of 36
Joe-Bouza
Mid between 2 points , is my preference
Joe Bouza
Message 22 of 36
Pointdump
Hi Joe,
Thank you. I hadn't used that one. Probably because it's Command Line Only:M2P.png
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 23 of 36
Joe-Bouza
its on my context menu. see post 4.
Joe Bouza
Message 24 of 36
Pointdump
Joe,
I looked at your Post #4 and thought, "That's handy. Why hadn't I noticed it before." It's amazing what you don't see when you're not looking for it. I had also not noticed, as Jeff mentioned, that "Geometric Center" is NOT in the right-click menu.Track_1.png
Dave
Dave Stoll
Las Vegas, Nevada
Message 25 of 36
AllenJessup
@Pointdump Dave, It's there in 2019. Also the command line alias is GCE.
Allen Jessup
CAD Manager - Designer
Message 26 of 36
Joe-Bouza
Hi Dave
yes very peculiar. I have a hunch Geometric Center comes from Architecture vertical
Joe Bouza
Message 27 of 36
codee
Make sure your object is flat.
Message 28 of 36
aaron_cotney
Hi all,,, again!
Is the only solution to move my drawing closer to 0,0 xy. It does seem to fix the issue but i do lose the xy coords of my drawing????
Aaron
Message 29 of 36
rl_jackson
Have you tried temporarily adjusting the UCS to a point near your data to see if that allows the Geometric Center to act correctly.
Rick Jackson
Survey CAD Technician VI
Message 30 of 36
aaron_cotney
Hi
yes i have tried moving the wcs origin closer to my drawing but that also changes the xy coord values, which i need to keep. But it does clear up the geometric center problem.. one thing leading to another. ☹️
Message 31 of 36
rl_jackson
No sir.....
I can set my UCS to a point close to my survey that is in State Plane, and create a new point and that point will have a Grid NE value that reflects its true position, the UCS has nothing to do with that.
Rick Jackson
Message 32 of 36
codee
Change UCS orgin. Do not change the world coords.
Message 33 of 36
AllenJessup
You can move you're UCS Origin closer to your drawing, do what you have to do and then restore it to World. No harm done. I'm still of the opinion that you shouldn't have to do this. But it's a good workaround for now.
Allen Jessup
Message 34 of 36
aaron_cotney
Hi all
I don’t think i’ll ever get to the bottom of this one.... think the M2P method is the closest i’m getting to an answer.
Would like to thank everyone for there help! Appreciate it 👍.
Message 35 of 36
AllenJessup
I was wrong. This is from AutoCAD 2019 NOT Civil 3D 2019. I was trying to use it in Civil 3D this morning and going crazy because I knew I had seen it.
Allen Jessup
Message 36 of 36
I had a similar issue. Try setting your SNAPBASE closer to your drawing objects. Your coordinate system 0,0 origin is to far away for AutoCAD to calculate the geometric center accurately when coordinates are in the millions.
