Hello all,
My Geographic Marker is getting in the way when I try to use the cube while viewing my 3D objects in Civil 3D 2016. I used the geomarkervisibility command to hide the geomarker, but that didn't seem to fix the problem. When I use the cube to view my object at a different angle, it seems to still think the geomarker is there and I want to view that.
Also, when using my free orbit, the system crahses if I use the zoomroll on my mouse at the same time, and also crashes while attempting to use the freeorbit tool at all.
Any help is appreciated,
Thanks!
Solved by ToddRogers-WPM. Go to Solution.
If you want to free orbit without crashing, the best way to do this is hold down the SHIFT key while holding down on the mouse wheel.
