Civil 3D Forum
Geographic Location keeps changing
18 REPLIES 18
Message 1 of 19
bnagel
504 Views, 18 Replies
So, I messed up & used the geographic location!! How do i undo it, get rid of the marker? It's really messing things up, even a new drawing that referenced to a nice aerial that was very believable.
18 REPLIES 18
Message 2 of 19
Pointdump
in reply to: bnagel
Bobby,
"Remove Location"
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 19
Jay_B
in reply to: bnagel
geomarkervisibility = 0
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 19
bnagel
in reply to: Pointdump
When I remove the location, it also removes my coordinate system. And now ALL of my drawings are not showing the proper map area. I'm somewhere in New Mexico!!! Grrrrr
Message 5 of 19
Pointdump
in reply to: bnagel
Bobby,
"When I remove the location, it also removes my coordinate system."
Yes. And then you re-assign the coordinate system with _MAPCSASSIGN.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 19
bnagel
Well, that got me closer! I'm now south of Amarillo!! I need to be in Tulsa, OK. NAD83, OK North Zone, US Survey feet.
Message 7 of 19
Pointdump
in reply to: bnagel
Bobby,
You're killing me. Let's take this one step at a time.
Your Post #1 said:
"...I messed up & used the geographic location!! How do i undo it, get rid of the marker?"
Remove Location fixes that. Then if you re-assign a coordinate system you should be good to go and can use Bing Live Maps again. So at this point you need to supply more details, post your drawing or screenshots or a screencast, so that we can see what you see.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 19
bnagel
LOL!! I kill myself, sometimes.
I removed the location but, there was still a marker point under Geographic Location-Edit Location. I figured out how to remove the marker location, which was in Lat/Long.
Then I converted a state plane coordinate point to Lat/Long and was able to re-orient the marker point to my coordinate point.
My map now looks correct.
Whew!!!
Message 9 of 19
bnagel
I alway take a drawing from a client and copy it over to my own template, thereby saving the integrity of the original drawing. I'm thinking my template may have the location marked somewhere out west, instead of none at all. I'll need to investigate.
You should know that I work for a construction company and all I do is create COGO points for layout work. I get drawings from all over the state!
Message 10 of 19
Pointdump
in reply to: bnagel
Bobby,
"I'm now south of Amarillo!"
Yup, your drawing is somewhere south of the desired Northern Oklahoma. Are you sure about the US Survey Feet units?
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 19
Pointdump
in reply to: bnagel
Bobby,
Curiouser and curiouser. When I open your drawing it has no coordinate system assigned. I assign OK83-NF and the Transformation Tab lights up and shifts your points and linework towards Amarillo. (I had dinner in Amarillo this last Saturday. Golden Corral is awesome there!) If I then turn off the Transformation Tab, the drawing gets closer but it's still off 2-300 feet to the East.
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 19
bnagel
I saw that as well. I was able to get a little closer with this drawing and using point #7 as a transformation point. Not sure I understand what transformation really does.
Message 13 of 19
bnagel
Look at how well this attached drawing comes in with the same coordinate zone.
Message 14 of 19
Pointdump
in reply to: bnagel
Bobby,
I've had mixed results in my attempts to understand the Transformation Tab, but one thing I know for sure it does is break Bing Live Maps. If you're confident of your points and linework, and just need to shift Live Maps a bit, @mathewkol has a really cool way:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/screencast/Main/Details/fe113525-2...
I'm opening up your last two drawings right now.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 19
bnagel
After watching the video, that's what I was doing!!!
Message 16 of 19
Pointdump
in reply to: bnagel
Bobby,
Close, but could use a little "adjusting". So you figured out how to do that by yourself?
Regent Prep Base:
Skiatook Municipal Base:
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 19
bnagel
Yes, I did!! I may or may not adjust. It's close enough for now.
Practice would help, though.
Message 18 of 19
bnagel
How do you make those screenshots, and mark them up?
Message 19 of 19
Pointdump
in reply to: bnagel
Bobby,
One of the keys on your keyboard should say "prt sc" or some such. Hit that, open up Microsoft Paint, and hit paste. Inside Paint you can crop, add arrows, rectangles, lines, text, etc. Once you're done, save as a PNG and then you can put the image "inline" or as an attachment.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
