I'm using General Segment Labels to label the elevations of contour polylines. The frustrating part of these labels is that they will move along the polyline if the polyline is stretched, trimmed, or extended. Is there a way to pin the label? The label properties show a place for pinning, but I can't find a way to toggle this function (see attached screenshot). Thanks!
~Steve
Rick Jackson
Survey CAD Technician VI
Set the anchor point to Label Location. Make sure you are changing it on the proper component and not the Table Tag
I think its just the nature of the general segment label beast.
The label is tagged to a certain segment number of the polyline when it is placed. If you add segments to the end of the line/curve all if fine. If you add to the beginning, they shift to get back to the same segment number they were on.
If it is anchored to the middle it will move to the middle as the line/curve gets longer or shorter. If it is anchored to 'label location' it will move proportionately.
That's a pretty good explanation. I wonder if there is a better way to label the elevation of a polyline...
Rick Jackson
I must be missing something. When I try that it asks that I "Select a surface" first. I can't select the polyline using that command.
Joe Bouza
