General Segment Label - missing numbers
F.Camargo
Advisor Advisor
Message 1 of 15
F.Camargo
Hi all,
How are you?
How can I find 7 - 8 - 9 tag numbers, please?
Fabricio
Replies (14)
Message 2 of 15
ecfernandez
Hi @F.Camargo, have you searched the whole alignment and the label is not located anywhere else on other curve?
Camilo Fernández
P.Eng | Transportation
LinkedIn
Message 3 of 15
F.Camargo
@ecfernandez  escreveu:
Isn't alignment label, just a label.
Yes! I've already tried select similiar and didn't work.
When I select everything (Crtl+A) and erased that worked. But I wanna delete all my drawing.
Message 4 of 15
user181
Civil 3D skips curve label numbers all the time. It's happened in every version of Civil 3D I've used. I usually use the renumber option after they are created.
Message 5 of 15
F.Camargo
@user181  escreveu:
Hi
It is not working .... still missing 7 - 8 - 9 so far.
I don't know how to fix it! Maybe it is missing in same place in my drawing, but I can't find it!
Message 6 of 15
Joe-Bouza
Is there another alignment using the labels?
Joe Bouza
Message 7 of 15
user181
I can open a new drawing with nothing in it and the first thing I label the numbers skip. I've never seen it work correctly. I usually have to rename them changing the start number never works.
Message 8 of 15
Ragdern
Are you using curve tags instead of table tags for some arcs? Those than reserve the tag number in some situations leading to missing/non-overwritable tag numbers.
Message 9 of 15
F.Camargo
@Joe-Bouza  escreveu:
I have just 9 General Segment Label (C1-C2-C3-C4-C5-C6-C10-C11-C12).
I don't understand why are missing 7-8-9 labels 😵
Message 10 of 15
Joe-Bouza
Did/can you share the drawing.
i do not immediate access to cad and may later
Joe Bouza
Message 11 of 15
F.Camargo
I have two labels style with " Table Tag". It is the problem!!
I don't use table tag in "01-Medidas de Lotes" Style and it can't be deleted.
just wanna using Table Tag numbers in "Descrição de Curvas" style.
Help me, please guys!
Message 12 of 15
Ragdern
You can renumber or remove the parcel labels. Renumbering will free up 7-9 for your curve labels. From your other screenshot you have quite a few parcel segment labels. 7-9 are maybe there somewhere.
Message 13 of 15
F.Camargo
I have about 400 label in that Parcel label style "01-Medidas de Lotes". I cant' delete that style.
But that style causing that issue, I couldn't renumbers the curve General Curve Label Style "Descrição de Curvas" (1, 2 and so on cause that number is already existing in "Table Tag" Parcel label)
Can I overwrite the number on "Descrição de Curvas" style? There is no problem duplicated the numbers in different style for me.
Message 14 of 15
F.Camargo
It have a label style named "Descrição Curva" in General - Label Style.
And other label named "01-Medidas de Lotes" in Parcel - Label Style.
Are theses styles have the same Component name: Table Tag? I can't not using the same number for that styles.
is there any option to allow to duplicated table tag?
Thank in advance
Fabricio
Message 15 of 15
akabiriHPS93
Community Visitor
Community Visitor
Follow these two steps:
Step 1: Create and Apply the Labels
  1. Edit Label Style: Open the style settings for the labels you are working with.
  2. Access General Settings: Navigate to the General tab within the style editor.
  3. Set Display Mode: Ensure the Display Mode is set to Label.
  4. Apply to Segments: Add these labels to your desired segments in the drawing.
Step 2: Convert Labels to Tags
  1. Re-Edit Label Style: Return to the label style settings.
  2. Access General Settings: Go back to the General tab.
  3. Switch to Tag Mode: Change the Display Mode from Label to Tag.
