From the research I've done, I found a few posts on how to change the format of the bearing or the units of precision for the distance but what I'd like to change is the wording.
Rather than:
Thence, S 00° 02' 33" E for a distance of 108.00 feet to a point on a line.
I'd like it to read:
Thence S 00° 02' 33" E, 108.00 feet;
Is there an xml file where I can make these changes?
Thank you
Rather than:
Thank you
Solved by rl_jackson. Go to Solution.
If you go to report settings it will show the location of the XML files which can be edited using XMLNotepad or other software.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
