Hello everyone....
I need to create offset alignment from another one...(because i have two widening located in one place (superimposed)). my second offset alignment has gap in place where the transition of centerline ends.
Is there a way to handle this issue?
Thanks in advance
Solved by SoaresASBCAD. Go to Solution.
Thank you so very much! I changed transition type of offset alignment parameters from linear to Curve-Line-Curve. and there is no gap.
