Formatting Data Band when printing Profile View
Daniel.Sultana4LBPG
Daniel.Sultana4LBPG
Hello Everyone.
I am trying to print my profile view but I am not using the create view frame options. my problem is my data band elevation values gets misaligned with the ticks in the view port. I tried adjusting some settings in the "Edit Profile View Style" and "Edit Band Style" settings but with no luck. I would appreciate any help I can get.
michal.holda.
Autodesk Support
Autodesk Support
Hi @Daniel.Sultana4LBPG
Could you please try one of the following to see if this makes any difference?
  • Pin any labels if possible.
  • Remove any axis offsets from the Profile View. You can find axis offsets in Profile View Style>Grid tab.
  • Delete Viewports from a layout so that there are not multiple Viewports with different scales.
  • Set the Viewports to the same scale.
andrewpuller3811
It looks like the labels in the viewport are being "staggered" to try and fit them in.
You could change the staggering setting in the profile view properties to no staggering.
Also I would suggest setting your model space view scale to match the scale that you viewport is set to. This will show you in model space how the bands are going to appear through your viewport.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
