I have always been in troubles setting up the labels for profiles and cross section, so the labels are a mess, I'm open to suggestions of how can I improve the setup for this environment. On the other hand I am having several issues in the volume calculation process and cross section printing for a corridor:
- The first one is the profile of "Eje 3" which shows me some cut&fill but when I go to the report it seems the quantities reported are not matching with accordingly to the heights of cut&fill. Also in the band I set up a cut and fill band and it only shows me values of 1 and 2 (I expected the volumes for the respective RP), so I don't know how to set up this to reflect the correct values.
- After implementing the corridor in "Eje 3", I take as a base for the cut&fill the EG (Topo Urbanismos Surface) and since I only need the volume for dirt removal I calculate based on the FG (Eje 3 Surf) The cross sections, which I obtained creating a corridor surface from the corridor surface tab and setting it up as top link.
- The assembly I built it up with a 3.00 m width and dayligthing with (0.5:1) cut and (1.5:1) fill but I don't find a simple template for setting up just the daylight cut&fill, so when I plot it it shows me some other set up and I don't know how correct it just to show me the cut/fill slope right after the 3.00 m road width. That ends when I print the cross sections it shows me the FG, EG, and also shows me a assembly wat too different to the one I set up and with different set up.
- When I review the corridor sections it seems to be showing correctly the FG vs EG. But the cross sections are not, in some of the sections shows the EG and FG, in another one shows the assembly, and another one shows the cut & fill material surface. So I'm completely lost with this and have not been able to set this up correctly.
- In the picture for section view properties it shows different widths for every section and I don't know what I did wrong to set that up, I was assuming it tooks the assembly width and plot it that way.
I excuse myfself for so messy drawing but, as you can see I have big issues setting up this drawing and of course to be certain the volumes shown are correct. I will aprecciate your inputs on what am I doing wrong with the setup of the assembly so the cross section is not executing correctly and giving me different values and sorry for such a mess of the drawing.
Attach some pictures of the profile, sections and the dwg file for reference.
Thanks in advance.
Carlos Andres Toro
