Hello
We surveyed a vertical wall. I created a surface from the measured points. The wall has a rough unfinished surface. I need to find the distance between the surface and a design line that is roughly parallel to the wall. I created points along the design line and now need to find the distance from the points to the surface.
Thank you
John
Solved by hippe013. Go to Solution.
Solved by Neilw_05. Go to Solution.
Hello
I don't need to calculate volumes. I have to show the distances between the existing wall and it's final location. The distances will be used to erect the forms to pour the concrete in its final location.
Thank you
John
Hello
I don't need to calculate volumes. I have to show the distances between the existing wall and it's final location. The distances will be used to erect the forms to pour the concrete in its final location. I understood what you did, is there any way to extract the distances along the original red line? Your help is greatly appreciated.
Thank you
John
Create a Surface Spot Elevations label wherever you want to know the distance.
At any point on a volume surface, the "elevation" is the difference between the Comparison surface (face of new concrete) and the Base surface (existing wall).
A negative (-) volume surface elevation means Cut/chip away; *
A positive (+) volume surface elevation means Fill/add new concrete; *
A zero (0) volume surface elevation means the existing wall is at the final location, no cut or fill. *
* Signs are reversed if you have the Comparison and Base surfaces defined wrong.
This is just a general thought: Do you need to chip away so the entire finished wall is smooth concrete, say 1" minimum thickness? If so, you will have all cut.
Christopher Stevens
Sorry, this statement is incorrect.
@ChrisRS wrote:This is just a general thought: Do you need to chip away so the entire finished wall is smooth concrete, say 1" minimum thickness? If so, you will have all cut.
Christopher Stevens
Hello
Sorry for the delay, there have been some serious issues at work. I rotated the measured points, and the vertical design line of the wall, around the line that is perpendicular to the vertical design line of the wall. I created a surface from the rotated points. You can see this in the attached jpeg file. I then drew a 3D polyline along the design line, connecting the points that I previously created along the design line. The elevations of the points along the line were all zero. I then used the Elevations from Surface command which resulted in the vertices of the 3D polyline getting elevations from the surface. The dwg file is also attached. I think that the elevations are the answer that I am looking for. Is this correct?
John
John
Hello
Sorry for taking so long, there were some serious problems at work. I did what you suggested and it worked. Someone else calculated the volume a different way and it was basically the same. Many thanks.
John
