Find specfic elevation on Featureline
AllenJessup
Mentor Mentor
Message 1 of 14
AllenJessup
I thought I'd find this through a search. But I haven't turned up anything yet.
I have a Featureline going up a slope and want to hold a certain slope and find where on the Featureline a specific elevation falls. I can calculate it from the final elevation or draw a polyline at the specific elevation, interposed on the Featureline, and use it to trim the Featureline. But I'm always looking for better ways of doing things.
So does anyone know of a better way to find where elevation 440.0 falls on a featureline?
Allen Jessup
CAD Manager - Designer
Replies (13)
Message 2 of 14
Ranjit_Singh
I do exactly that but instead of trimming, I start a new line and use the intersect osnap to see where that elevation is.
I would also like to know if there is a better way.
Message 3 of 14
AllenJessup
I just added another way. Set the units to 8 decimal places and draw a line using the Nearest Osnap. Run the Osnap along the Featureline and watch the elevation. I can usually hit the elevation with zeros out to 5 decimal places.
Allen Jessup
Message 4 of 14
Joe-Bouza
Joe Bouza
Message 5 of 14
AllenJessup
Nice one Joe! Thanks.
Allen Jessup
Message 6 of 14
TerryDotson
If you were to consider third party add-ons, C3D FeatureTools contains a mark tool that will mark a specified elevation on all segments of a selection set of featurelines (or 3dPolys, etc) in a singe, quick operation (no jumping through hoops).  This tool places a point object, a companion break tool does the same if you want to chop them up.
Message 7 of 14
AllenJessup
Looks nice Terry. We're just not buying anything right now.
Thanks.
Allen Jessup
Message 8 of 14
Joe-Bouza
No solution Smiley Surprised ... comon I trying to topple Tim Smiley Wink
Joe Bouza
Message 9 of 14
AllenJessup
I was getting to it. Figured I'd give others a chance to top you. Smiley Wink
Allen Jessup
Message 10 of 14
Joe-Bouza
Smiley Wink
Joe Bouza
Message 11 of 14
Ranjit_Singh
Here is just one more way using lisp
Spoiler
;created by Ranjit Singh, 11/29/2016
;marks elevation points on feature lines
(vl-load-com) (defun c:setelpt (/ vlaObj pts el pt modelspace adoc) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end")) (princ (strcat "\nError: " errmsg))) (vla-endundomark adoc) (princ)) (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (setq vlaObj (vlax-ename->vla-object (car (entsel))) pts (vl-remove-if '(lambda (x) (atom x)) (test (vlax-invoke vlaObj 'GetPoints))) modelspace (vla-get-modelspace adoc)) (initget 1) (setq el (getreal "\nElevation to be identified :")) (while el (mapcar '(lambda (x y) (if (setq pt (inters x y (append (reverse (cdr (reverse x))) (list el)) (append (reverse (cdr (reverse y))) (list el)) T)) (vla-AddPoint modelSpace (vlax-3d-point pt)))) pts (cdr pts)) (initget 1) (setq el (getreal "\nElevation to be identified :"))) (*error* "end")) (defun test (x) (cond ((null x) pts) (T (append (list (list (car x) (cadr x) (caddr x))) (test (member (cadddr x) x))))))
Spoiler
Message 12 of 14
AllenJessup
Very nice. That will come in handy.
Allen Jessup
Message 13 of 14
MeowdyFren
I know that this is an old post, but I am curious if you have used this lisp recently. When I try to run the lisp, I get an error "Hard error occurred *** internal stack limit reached (simulated)". I am running civil 3d 2018. Have you been able to run this lisp on this version? I would love to be able to use this with a project I am currently working on.
Thank You!
-Meow
Message 14 of 14
AllenJessup
It's working for me in 2020.2. Are you working at very high or negative elevations?
Allen Jessup
