Hello.
I have a layout template for plan over plan viewports (2 viewports).
I tried to insert a field of the starting station of the first viewframe and the end station of the second viewframe, but I did not find any field about station.
I also want to number each created layout like the number of sheet of total of sheets. I also did not find any field regarding current viewframe number and total number of viewframes.
It is possible to automate this task with a plain Civil 3D commands or should I have to do it manually?
Greetings from Paraguay.
Claudio Bogado Pompa.
Matchlines should have the fields. ... wait a minute? Are you looking at fields under the FIELDS command? not there
in the label style setting s of view frames and match lines
Joe Bouza
I was trying to insert the fields in a title block multi line text field.
Is there a way to insert the labels in a multi line text field of a title block?
I did not found a way to insert a page number field and total number of pages in the title blocks.
I coded a custom command to change the attribute reference of each title block on every layout.
