I am trying to create a featureline from a 2d polyline with elevations from the surface. However when I try to do this the vertices on the feature line remain at zero (I like to draw p lines with 0.00 elevation). There must be a simple solution to this, but I cannot find it.
Any help is appreciated.
Thanks!
Solved by AllenJessup. Go to Solution.
My first guess is that those two vertices fall outside the surface. My second would be that the featurelines cross other featurelines in the site that have an elevation of zero.
Allen Jessup
CAD Manager - Designer
Hello @Anonymous
I also agree with Allen that those two vertices may fall outside your surface or cross another feature line. Maybe you can post a picture of those feature lines to and turn on your surface triangles to confrim. Thanks
Wendell
Hello @Anonymous
I'm just checking in to see if you need more help with this. Did my reply and @AllenJessup helps solve your featureline vertice problems?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
