Featureline levels not picking up triangle sides
neilyj666
Mentor Mentor
Message 1 of 12
neilyj666
I trying to get a feature line to pick up the levels from triangulation using intermediate gradient break points but it doesn't grab them all (see below yellow circled areas) and I have no idea why - anyone got any ideas?
thanks
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (11)
Message 2 of 12
AllenJessup
Try creating a Proximity Breakline.
I think I'm wrong about that. I thought it would pick up where it crossed the triangles. But it looks like it would pull the elevation from the closest vertex.
Allen Jessup
CAD Manager - Designer
Message 3 of 12
brian.strandberg
That is very unusual.  I know the UKIE country kit just came out, maybe some weird interaction there?
Any chance you can share the drawing?  I'm going to do some checking on my side as that is very odd.  I'm also wondering if those triangles are all the same slope so something is saying we don't need an intermediate grade breakpoint there.  That's not how it should work obviously.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 4 of 12
brian.strandberg
Stupid question - those triangles are from the same surface right?  No, very stupid question.
Message 5 of 12
neilyj666
@brian.strandberg I can't use the UKIE Kit as Prospector doesn't work properly (see separate thread; I have a Support Case opened on this one) but I attach the drawing (shifted from its real world location as I can't share it) with the surface an a polyline that needs to be converted to Feature and pick up all the triangle intersections.
As my ultimate goal is to remove all the triangles east of the polyline, my workaround is going to be to create a boundary to use an outer but this doesn't get to the root problem of the featureline not picking up all the intersections.
Message 6 of 12
neilyj666
Yes - proximity BL's will only get the nearest point level.
I think I can workaround by creating an outer boundary but this doesn't address the issue of the FL not picking up all intersections - I have attached the drawing in another reply to @brian.strandberg so I'd be grateful if you could try the same thing before i raise a support case
Message 7 of 12
Joe-Bouza
I extracted the border and create a closed bpoly used as an outer boundary and checked non destructive break and the edge elevations along the poly line seem to match. is that what you are looking for?
oops! the root of the problem, gottcha
Joe Bouza
Message 8 of 12
Joe-Bouza
Have you tried MAPCLEAN the poly line?
I exploded the pline MAPCLEANED to pline>> FL >>> elevation from and appears to pickup triangle locations
Joe Bouza
Message 9 of 12
Joe-Bouza
Joe Bouza
Message 10 of 12
neilyj666
@Joe-Bouza that appears to have sorted it - the polyline was originally derived from the min dist between surfaces and I ran overkill as this usually works but didn't think of MAPCLEAN
Just wish things would work without resorting to PURGE, AUDIT, OVERKILL, MAPCLEAN, WBLOCK, RECOVER etc etc; I dread to think how much time I've used troubleshooting dodgy dwg files
Message 11 of 12
brian.strandberg
Sorry I didn't see your message until the next day, I really needed to get away from my computer yesterday.  I'm glad you were able to get it sorted out.
Message 12 of 12
Joe-Bouza
Glad it worked for you.
I hear what your saying. I come to live with always cleaning geometry to use for civil3d, but in this case the geo was derived from civil3d, can be frustrating
Joe Bouza
