I fail to select a feature line from corridor. I have to select All first and isolate the one I want!
I can see the feature line, in this case Crown but unable to pick it.
Sometimes it says "one selected one filtered out".
I tried all Code Set Styles but the problem remains.
Option 1
Simply select the "All" option on the command line, and then select the feature line you want in the dialog box that appears.
Option 2
Check if you are able to select a corridor feature line in plan view.
Thanks!
Yes that works but a few FL are selected not just one.
Jeff B has a clip on Youtube and he is able to select one FL but I never been able to do that!
can you give a link to that clip? I know that corridor feature line extraction changed in one of the more recent releases. My recommendation is go with the all, then deselect the ones you dont need from the list.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
