I have a drawing with many points, each of which has an elevation. Is it possible to draw a feature line from point elevation to point elevation without having to laboriously enter the elevation of each point? That could take hours in a large drawing, and leaves a lot of room for copying error.
Thanks!
When prompted to select a point for your feature line, use the transparent commands: Point Number ('PN), Point Name ('PA), Point Object ('PO), etc.
Yep, same as the last time you asked.
