Fatel Error
Fatel Error
asawan_4u
Observer Observer
Fatel Error
asawan_4u
Observer
Observer
When I Doing work in civil 3d with  10 thousands points software going to held and suddenly shutdown with fatal error
pendean
Community Legend
Community Legend
What is your C3D version? Is it fully updated?
What is your WIndows version?
Is this a sudden new problem?
Is it limited to this one file? Did you try and fix the file?
M_c3d
As @pendean says more information is needed...
...but as a starter depending on how the file is set up, how extensive it is etc, it could be your pc is maxing out on ram. As a starter I would suggest you use data shortcuts where possible to ensure you keep file sizes down and more manageable.
BushW
Hello @asawan_4u
I agree with @pendean we need more information to help you.
Can you tell us what you were doing when this happened? Any additional information you can provide will significantly help in solving your issue. Thanks
Wendell Bush
Civil Infrastructure Technical Support Specialist
BushW
Hello @asawan_4u
I just wanted to follow up here, any progress on this issue?
Best Regards,
Wendell Bush
