I have been getting fatal errors using the DIM command on a layout drawing. We use a model drawing then xref it into the layout drawing for plotting. While putting the dimensions on this LOD in the current drawing I get a fatal error when using the DIM and then have to start all over. I looked up the issue and found that I need to use AUDIT, then PURGE. Neither has helped. The other thing is this process takes so long but my processor isn't working that hard. Attached is the
