Civil 3D Forum
Extrude preview
5 REPLIES 5
575 Views, 5 Replies
Extrude preview
I'm trying to extrude a series of 3D faces, a very large series, over 200,000 3D faces. I´ve done this before only it was not on so many faces as I can select only like 3,000 faces aprox at any one time or the computer crashes.
I think this problem could be solved, or at least I could save some time, if the extruding preview could be turned off. By extruding preview I mean that when I enter the extrude command and select the objects to extrude, then immediatly there's a preview of what the objects would look like once they're extruded and that's what's causing the delay and the crashes.
Is there any way this could be turned off?
I've attached an image in case I didn't explain myself.
Thank you and I'm sorry if this post is not in the right place.
5 REPLIES 5
troma
Maybe somewhere over here you can find more answers:
http://forums.autodesk.com/t5/AutoCAD/ct-p/8
Mark Green
Working on Civil 3D in Canada
tcorey
Try the attached lisp routine. This will make a selection set of your 3dFaces, ask for an extrusion height and will go through and individually extrude the faces. It can take a long time, so be patient.
I changed the .lsp file to .txt so that I could post here. You will need to change the file extension back to .lsp to make it loadable in AutoCAD.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Whoa! thanks, only I need to extrude in the Z direction, 300 meters down. i. e. from (0,0,0) to (0,0,-300).
Thanks for replying
antoniovinci
Well, if your goal is to solidify-and-extrude a surface, you'd better start from here...
in reply to: antoniovinci
Yeah that's exactly what I want to do, but I don't know what to do after creating the 3dmesh.
Thanks.
Rail Community
