Hi @qchenTPPXV, You can use the command OFFSETFEATURE. This works with polylines, 3d polylines, parcels, featurelines & survey figures. You will have to add an offset distance because like what others have mentioned you can not have sheer vertical faces within Civil 3d surfaces, but you can specify something really small like .01. We typically do this for curbs, walls, exposed slabs; just situations where we need something vertical but with a slight angle. Make sure you offset towards the inside of your 3d polyline.
After selecting your horizontal offset, you can now specify your vertical offset, you have the choice of: Slope, Grade, Difference, Variable or in your case Elevation.
In the picture above, I just converted the 3d polylines to feature lines and used those to define the surface. The bottom feature line has varying elevations, but the top is all set to one constant.
