Extracting Slope Bands
makaosant21
Observer Observer
makaosant21
Observer
Observer
Hi
I currently have a surface from lidar data and isolated a slope range using the slope analysis and slope banding surface style. I selected this surface and extracted the objects and they resulted in 2D Solids (since I set it that way) but there are too many. Each triangle is extracted.
Is there a way to quickly combine congruent areas to create one solid?
The output Im trying to achieve is a plan view KMZ but the filesize and the amount if objects crash the software. Any ideas? https://100001.onl/
igi_pop
Hey,
Unfortunatley, if you create a solid from surface, it will still use ALL triangles.
If you extract them, the extrusion is a choke machine.
My recommendation, do this task in a GIS enviroment 🙂
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
igi_pop
To give you an idea, here are some screenshots:
DataDatashadedshadedSlope analisys (50-120%)Slope analisys (50-120%)Google EarthGoogle Earth
AllenJessup
Try the Union command. If the triangular solids are clean enough. They should join.
Allen Jessup
CAD Manager - Designer
