Civil 3D Forum
Extra marks on corridor sections
6 REPLIES 6
unkind38
407 Views, 6 Replies
Hi.
Tell me how you can automatically remove the extra red and black marks on the cross-section profile of the corridor?
How to make sure that the marks were put only in the right places?
A large accumulation of marks is very difficult to manually remove these marks is very inconvenient and long.
6 REPLIES 6
ytzvib
in reply to: unkind38
You probably have to edit the bands for profile select the profile view properties and you can see the band styles on the band tab. For crossections select group properties scroll to the right and then you will see on the top bands select the small button next to the word bands to edit it.
unkind38
in reply to: ytzvib
Thanks.
If you can make screenshots. A little misunderstood.
Jeew-m
Dear unkind38,
I hope the post of Jowenn in this thread will help you in this case.
https://forums.autodesk.com/t5/civil-3d-forum/cross-section-labeling-issue/td-p/8539491
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
ytzvib
Please see the attached image of all the dialog boxes to reach the Band labels for crossections.
Start by selecting your crossection and then press the buttons as shown.
If you need more assistance please attach your drawing so I can give you exact instructions.
ytzvib
Basically what is happening is that your crossections have a lot of grade breaks so the band gives information for each one.
To change that go to the band properties and if you scroll to the right add a distance to weeding and the band will update based on that. See screenshot (see crossection in the corner, with the weeding set to 1 it does not have overlapping numbers.)
unkind38
in reply to: ytzvib
Excellent solution. Thanks for your help.
Rail Community
