Civil 3D Forum
Extent of rockfall netting
10 REPLIES 10
Message 1 of 11
neilyj666
609 Views, 10 Replies
I have a model of a platform at 29.00m cut into rock and need to find  areas where the rock cut is 2m or more as this will require netting - any ideas of a quick way to do this??
 Extract the 31m contour and see where it runs is the best I've come up with......
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
10 REPLIES 10
Message 2 of 11
Neilw_05
in reply to: neilyj666
Would not a CUT/FILL depth analysis work?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 3 of 11
neilyj666
in reply to: Neilw_05
The excavation surface vs a 31m plane surface??
Message 4 of 11
Neilw_05
I don't understand your scenario. I assumed you have a proposed surface and want to determine where the cuts are >2m vs. the existing. What do you have to work with?
WIN 10 64 PRO
Message 5 of 11
neilyj666
Yes I have a proposed surface and I'm only really interested in the portion that is below rockhead and is higher than 2m above the platform level
Message 6 of 11
Neilw_05
In the ranges for the depth analysis, only include those values that fall within the desired parameters.
WIN 10 64 PRO
Message 7 of 11
BrianHailey
No. Create a volume surface of your platform and your rock surface. Run an elevation analysis on the volume surface. Anywhere the elevation of the volume surface is greater than 2m is where you will need the protection. You can then stylize the volume surface and to display those areas automatically if the design changes.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 11
Neilw_05
I assumed you knew how to create a cut/fill analysis. My apology for not being more explicit.
WIN 10 64 PRO
Message 9 of 11
neilyj666
in reply to: BrianHailey
Thanks Brian I'll try that ....
This will identify the locations where the rock netting is required but the next task is to compute the area of the rock face to be netted.
Perhaps draw a boundary around the affected areas, apply as outer boundary and review the 3D area surface properties??
Message 10 of 11
I just checked and I believe in the Legend table for volumes you can add 3d area or 2d area.  We use it all the time in the slopes legends to calculate sq footage of walls.
Hope that helps,
Conan Witzel
Message 11 of 11
user contours on a volume surface can help capture the 2d area from plan view.
Rail Community
