I was trying to get a label style to display depth to soffit of pipe. I tried using start and end cover label styles but they give the depth to the centre of pipe and not soffit. So I created the expression:
{Start Cover}-({Pipe Inner Diameter or Width}/2)
But when I add this expression to the label style and put the label on a pipe it shows it as only the name of the expression. I know I haven't included the wall thickness but that is because I have set the wall thickness to zero.
Can someone please explain why the expression is not working.
