Exporting Revit Model to Civil3D with automatically generating Civil 3D objects
MehtaRajesh
MehtaRajesh
Objective: Exporting Revit Model to Civil3D with automatically generating Civil 3D objects
Requirement:
We have a requirement to export Revit model into civil 3D
The requirement is basically related to Pipe and Pressure Network.
Idea is to automatically convert Revit Pipe families to Civil Parts accordingly.
At Present when we export CAD file from Revit and opening in Civil3D, the components is not automatically converted to Civil3D objects
Any Support in this regard will be very helpful
Regards
Rajesh
jrauch
Just so you don't think everyone is ignoring you... I'll stick my neck out a bit and respond with some news you probably don't want to hear. You're going to have to hack at this pretty hard. I'm thinking maybe going through AutoCAD, stm, or shapefile... there's no way it's going to be seamless, and there's going to be data loss. Perhaps someone who's done this successfully has a creative solution they've cooked up, but to my knowledge, there's no "easy button."
-John J. Rauch, P.E.
MehtaRajesh
Thanks John, for sharing your thoughts.
If any progress we will make on this idea, will share it in this forum
Rajesh
MikeEvansUK
Rajesh, I figured I can lend some comments and possibilities here.
Firstly I am confused as you seem to be suggesting the conversion of pipework is from Revit to Civil3d, surely you mean the other way around?
Why on earth would you use Revit to design below ground pipework when Civil3d does the job a whole lot better?
If you mean from a Mechanical to Civils interface then I would just use IFC (see below)
Now with regard to your question.
No it is not possible without some huge workarounds which in my opinion makes it not worth doing. It does depend what you are trying to achieve; if its for coordination between the team then just use IFC or a 3d solid export & "an actual plan drawing".
You could as John suggests export from Revit but I would consider the following method;
Export IFC & import to Civil3d, manually convert IFC data to a map object data table then export to Shp. Import the shape and convert to pipe network.
Please note unless you know programming (and even then) transferring the details from object Properties to Map data tables will take ages as it has to be manually typed and there it throws in the risk of human error so needs to be rigorously checked.
I have seen designs of underground pipework in revit which range from hideous to almost usable. You need to edit the pipework and add data manually.
Civil3d is designed to be automated that is; The pipe uses a defined surface to obtain the cover levels at either end and every 1/3rd the way along. Using this and rules you can control the depth of the pipe and the gradient (also tied to size) and design with relative ease.
Information can (with a little work to set up) be automated and passed from Civil3d into revit as an IFC export containing all information for each pipe / structure as shared parameters. This is what we do here and it really works well.
In short my advice, ditch Revit for below ground pipework and use Civi3d. interpolate between with IFC.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Joe-Bouza
I know nothing but I here this is the way of the future for sharing models?
https://bim360.autodesk.com/
Joe Bouza
jrauch
If by "way of the future" you mean, "this does not currently support Civil 3D objects, but wouldn't it be nice if it did," then I wholeheartedly agree.
tmachado
Hi @MehtaRajesh, here is a link to an article that may help:
http://civil3dbtf.blogspot.com/2016/02/how-to-assign-coordinate-system-to.html
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
