Announcements
Exporting Contours from AutoCAD Map 3D
tvermeulen
tvermeulen
I'm trying to bring in contours that I created in AutoCAD Map 3D from a raster image .tif. When I bring them into Civil 3D they have no surface elevation to them, despite having that data in AutoCAD Map 3D. Does anyone know the correct way to export out the data and import it into Civil 3D so that I can create a surface from the polylines?
Thank you
Replies (15)
ToddRogers-WPM
Ah yes. So, when your export them out of Map, you MUST add Elevation from the Data tab, Select Attributes button. This will map the elevation.
Todd Rogers
ToddRogers-WPM
If you would like me to record my screen to show you how, please attach the drawing with the contours and I will gladly show you how.
Todd Rogers
tvermeulen
I have just been exporting out the current map to DWG, am I missing a step where I can just export out the contours and then select that attribute?
tvermeulen
Attached is the Drawing. Thank you!
ToddRogers-WPM
The drawing attached is an empty drawing. Did you forget to save it?
Todd Rogers
ToddRogers-WPM
I see what it is. It's FDO data. Can you attach the shapefile?
Todd Rogers
ToddRogers-WPM
Todd Rogers
tvermeulen
The actual shapefile is massive, it's 100,000 Square feet
tvermeulen
And it won't let me attach the SDF's
ToddRogers-WPM
Oh man. Ok. Let me dig up a shapefile and then I'll create the video. Stand by...
Todd Rogers
ToddRogers-WPM
Todd Rogers
tvermeulen
Appreciate your time and the help Todd! That is exactly what I was looking for!
ToddRogers-WPM
My pleasure! Glad I could help!
Todd Rogers
Pointdump
Good video Todd!
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
ToddRogers-WPM
Thanks Dave!
Todd Rogers
