Exporting chainages and levels data from Civil 3D to Excel and/or word text
Hello guys,
i have created a profile from an alignment and now I need to extract and/or export chainages (at regular intevals) and their levels that I have created on a profile so as to use them in my hydraulic calculations. How can I do this? I have not found a way of exporting them in as texts or excel file.
Replies (16)
Jeew-m
Dear friend,
I hope you can do it through Report manager.
Try this and get an idea.
https://www.youtube.com/watch?v=N0i8xXn0ub8
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Mike.M.Carlson
In addition to @Jeew-m helpful tip, another option that I find easier/more flexible is to Create COGO Points by Measure Alignment.  You can select your CL Profile and specify the station range and sample increment.  Then you can export the created points to .csv where you can play with the data.  Use FIND command in Excel to take out the Station ID text you don't want.  Please see below:
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Dear @Mike.M.Carlson,
I have followed your video and i magaed to create cogo points. However when viewing and/or exporting the newly created points i cant see any changes.Its only outputting the same points i had before. What could be the problem?
I am attaching two dwg files:
1. Kanyabayonga xy infra option: this is my initial file
2.elevation and chainage at 25m interavl: this is the file after creating cogo points...
It is not working
Fabrice
Jeew-m
Hope this is what you are looking for.
Jeewana Meegahage
Design Engineer
Also @Mike.M.Carlson,
When I try check out the chainages of PR Option 2, by taking the cumulative distance between every two chainages i get a distance longer than the alignment is(around 40m).Does it mean that this method is not giving correct measurements?
Mike.M.Carlson
Hello Fabrice-
I reviewed your files and see that the COGO points are created the way I would do it.  I see correlation (at least in 2D chainage) between initial Profile View and your COGO points.  In the image below you will see results.
I did have to modify your Profile View Style (Horizontal Axes to = 25m) though, as it was set to 20m before.
Are you looking for 3D slope chainage along existing ground?  If so, you will need Station Equations on your alignment to account for the slope distance.  There are 3rd party add-ons (for a cost) that will do this calculation relative to a ground surface and apply updated 3D Station Equations to your alignment 2D chainage.
Michael M. Carlson
CADD Manager
Many thanks for your message, this is the perfect solution. It has worked. Thanks a lot.
you asked me about the slope chainage or the ground level chanaige. This si actually a question i have been tinkling of solving.When i am doing my pipelines and i need to know the total length of my pipe(bearing in mind that i have both horizontal and vertical chainage in direction), how do i make civil #d account for it? this would help me [produce a bill of quantity of pipes that is correct.
Best regards,
Fabrice
Mike.M.Carlson
Hi Fabrice-
Unfortunately, there is no functionality in Civil 3D (out of the box) that will calculate 3D chainage.  There are 3rd party add-ons to Civil 3D that can do this.
Pipeline Industry Standard software is Skyline, but it comes at a cost:
http://www.bsdconsultinginc.com/skyline/
Steltman software
https://www.youtube.com/watch?v=zmPnHMU19jY
I hope this helps.
Michael M. Carlson
CADD Manager
I have seen the video but it is not quite what I need, the only problem with this is that the chainages are not at a set regular interval.
Thank you
Fabrice
hi , the solution worked but for the first alignment only, the second did not return levels but only the default 0.00.
Hi Mike, I followed the clip and it worked for my first alignment. I tried with next alignment  but the levels are not displaying instead it only display zero which is the default. Kindly assist
Mike.M.Carlson
Can you please share the problem file again and indicate which alignment you need chainage for?
Michael M. Carlson
CADD Manager
Sorry i missed your reply. i have attached the file.
when i select the alignment, it skips the dialogue box where i am suppose to select the surface
it skips this section, and i think its the source of the problem, cant figure out how to sortit skips this section, and i think its the source of the problem, cant figure out how to sort
i just solved it. it requires one to create a profile for alignment.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
