Export to AutoCAD from Civil 3D 2018
Message 1 of 11
hello,
i used export to dwg but the outpot i recieved is not complete
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Describe in more detail what items are missing (and isn't one of them a referenced image file that just needs to be re-referenced?).
And what settings did you choose here
Message 3 of 11
U can see in upper image the civil drawing and in the lower drawing the autocad output.
Message 4 of 11
pendean
Community Legend
Community Legend
Message 5 of 11
M_c3d
What civil 3d objects are missing?
Message 6 of 11
jrauch
Use ExportC3DDrawing instead of ExportToAutocad. You'll have better results.
-John J. Rauch, P.E.
Message 7 of 11
user181
Make sure you have object enablers installed view the civil 3D objects
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-civil-3d-201...
Message 8 of 11
BlackBox_
When exporting a Civil 3D drawing, be mindful of MLeaders (depending on version) & COGO on locked layers:
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6731955#M324054
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6740928#M324424
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
Message 9 of 11
BushW
Hello @Anonymous
I'm just checking in to see if you need more help with this? Did the replies of @user181 and @jrauch provided work for you?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 10 of 11
BushW
Hello @Anonymous
I just wanted to follow up here, are you still in need of help with this problem? Thanks for the update!
Best Regards,
Wendell
Wendell Bush
Message 11 of 11
None of these suggestions help successfully export. Even after landxml was reimported in blank drawing. Maybe its because of update is missing.
