Message 1 of 11
05:51 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Describe in more detail what items are missing (and isn't one of them a referenced image file that just needs to be re-referenced?).
And what settings did you choose here
U can see in upper image the civil drawing and in the lower drawing the autocad output.
Make sure you have object enablers installed view the civil 3D objects
When exporting a Civil 3D drawing, be mindful of MLeaders (depending on version) & COGO on locked layers:
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6731955#M324054
https://forums.autodesk.com/t5/autocad-civil-3d-forum/exporttoautocad-troubles/m-p/6740928#M324424
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
Hello @Anonymous
I'm just checking in to see if you need more help with this? Did the replies of @user181 and @jrauch provided work for you?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Hello @Anonymous
I just wanted to follow up here, are you still in need of help with this problem? Thanks for the update!
Best Regards,
Wendell
