Hi All
I am stumped, I thought it was my workflow and or overtaxing my machine and now I am thinking it might be more and hoping for an easy fix.
I need to Export to Autocad to transfer a Civil 3D topo into Revit and I am running into a critical issue. Critical in that I need to get these done and have sourced out all the workarounds that I know of.
EXPORTTOAUTOCAD is crashing to desktop on all files....
FATAL ERROR: Unhandled Access Violation Reading 0x0210 Exception at A4EA0AFh
I have done what I can to the file so that it only has the topo, point cloud removed, even working on my C drive and a fresh reboot with NO other applications running in the background to troubleshoot potential issues.
I checked for updates - none and will be checking the beta area next!
Is there anyone else getting this and is there a solution?
Thanks in advance
Export to Autocad has crashed for as long as I have used it (since 2005). If I ignore the crash messages the file gets created just fine. In this case you have to ignore the serious crash message.
There are 3 parts to learning software:
1. What the tools do
2. How to apply them
3. What are the defects
This is fits under part 3.
I have found that if you have Include sheets checked that the Export C3D Drawing command will crash with a fatal error every time. Make sure that is not checked and that the format you want is one version older than the one you really want. That's yet another bug that Autodesk has not fixed in many versions.
Try CIVILBATCHCONVERTER command.
Hi
I thought this was it, and I tried those changes and still no success.
Well in your case it really is crashing.
Have you tried using DWG TrueView and do a dwg convert and modify the conversion setup file format to explode AEC objects?
Hi
Works but for I need to link said Tin into Revit and create a surface, and dxf removes too many properties that are required.
Sigh, came so close! I have 13 topo files to bring into Revit..... and only 1 day to do it now.
I have attached the files for anyone to EXPORTTOAUTOCAD below - Good Luck!
https://drive.google.com/open?id=1_StyMnL_XvM1Sx4A-Ku8yEWLulo8xtpB
Samir Rezk
Technical Support Specialist
