Hi guys
I've got a question here, am I able to export the created surface( TIN surface) from Civil 3d and export it as ESRI shape file to be able to use on QGIS? I need QGIS to create a terrain(in TIF format) based on the surface I create on Civil 3d.
thanks
Hi Jack,
Welcome to the Autodesk Forums.
You can export a surface in Tiff format, or you can extract points or contours to create a shapefile.
More details please on what you're doing in QGIS.
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave
thanks for your prompt reply, and yes my final purpose is to get the surface running on the HEC-RAS to run the flood analysis, I've found the way to save the created surface as TIFF format( which the file format I want on the final step when everything finishes on QGIS). but here is another problem, when I open it on HEC-RAS, there is an error...
really need help .thanks
