Export Solid 3D from civil3D to Revit
mairh_tsek
mairh_tsek
Hello all,
I export some solid 3D from Civil 3D to .json and after I import them in Revit.
But in Revit the file is transparent (see image)..so when I export it in Navisworks I see nothing. I dont know why it is happened as some days before it works and I had a solid generic model in revit that I could also see it in Navisworks .
Do you have any idea ?
Thank you !
mairh_tsek
ok, I should go : V/G > Imported Categories > check Imports to Families..
MikeEvansUK
Why are you passing as Json to Revit?
Does IFC not work for you, IFC will pass information from property set data, create solid geometry which is sectionable.
See post here:https://forums.autodesk.com/t5/civil-3d-forum/civil-3d-pipe-network-to-revit/td-p/11185862
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
mairh_tsek
Thank you for your answer. I tried with .ifc, but when I imported it in Revit the geometry was completely crashed. I want also in Revit to have the corridors as Revit elements.
MikeEvansUK
When you say completely crashed, do you mean it was not accurate / moved when you zoom?
When importing, use Link IFC. Open the created file and manually move this closer to the Revit local grid.
Revit can't handle large coordinate systems and gets issues in displaying data accurately. Generally amending the location cleans the geometry up.
If you mean the file is corrupt or looses information, use a lower IFC version for the export...
M
Mike Evans
