Civil 3D pipe network to Revit
echen4Q977
echen4Q977
What is the best workflow to export Civil3D pipe network to Revit? I don't need the pipes have property, just need to be able to cut section, and be able to show in plan and 3D view.
Does Autodesk have good method to do this at 2022 release version? thanks
MikeEvansUK
The best way to pass informaiton to revit is using IFC.
It does take information across saved as property set data but if none exists it won't.
Using this and linking the IFC will create revit acceptable geometry which can be shown on sections but remains static / uneditable in revit.
The other option is a 3d solid (switch to 3d view, explode twice. This needs the Revit user to insert into a Generic Mass part then insert.
Problems exist with coordination, Revit doesn't use World coordinates like Civil3d however the coordinate system can be set up (in Revit) to enable overlay by shared coordinated but it is far better to also include a 3d cube at a known location (building grid, survey grid intersection) and a set level at the underside.
In this way the Revit user can check the insertion location is correct.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
