Civil 3D Forum
Export selected COGO point into autoCAD
2 REPLIES 2
gyangTZCRC
324 Views, 2 Replies
Hello, I am working on editing a survey file (made in Civil 3D) and make it easier to edit in autoCAD since our office if mostly CAD base. As the screenshot demonstrate below, all the COGO points in different color identify their own thing and sit on different layer. I know how to convert them to a CAD block via "Creating Block from COGO points", but the question is if it is possible to export selected - for example I want all the "tree" cogo points-  into one specific layer, and then do the same thing for sidewalk, so and so on. These points are all in a single point group, idk if I need to create different groups in order to archive what I describe above?
Very new to C3D, this is usually not my task but here I am...  I am using C3D 2024.
Thank you to yall!
Labels (1)
2 REPLIES 2
Neilw_05
in reply to: gyangTZCRC
Point groups allow you to filter the points based on descriptions, elevations, point numbers etc. Once a point group is created you can use them to select the points in that group. That allows you to put them on specific layers, export to CSV files, convert to blocks, etc. You can also use point groups to change the display of the points in a group. I think your first step should be to create point groups. From there you should be able to do everything else you need.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
gyangTZCRC
in reply to: Neilw_05
Thank you! I will give it a shot. Much appreciate your help!
Rail Community
