Hi All,
Having an issue when using the export for construction tool. I'am working in metric units, however when I use the tool the outputs are in feet. Can this work properly without having to go back and change the output manually to meters? Am I missing some other setting somewhere? Cheers
The tool
Original file is in Meters
Solved by _MG. Go to Solution.
Hi All,
This worked, post is from Jowennl https://forums.autodesk.com/t5/civil-3d-forum/export-to-acad-units-change/td-p/8307908
need to change some settings in the options menu even if you are working in metric.....
I'm resurrecting an old thread with a new issue.
I'm using Civil 3d 2022.2 and get this error when attempting to Export for Construction ANZ: "Access to the path 'C:\ExportForConstruction.xml' is denied"
That file does not exist on my C drive.
I should add, the file with the Corridor is saved on BIM360.
