EXPORT DWG TO KML/KMZ
sanetdikkumbura1950
sanetdikkumbura1950
hI,
This is a civil 3d drawing. This should be kml or kmz with all line type and parcel lines available here. (for google earth) Line type and parcel segments disappear when exported as usual. How to do it?
please help
VincentSheehan
You may need to export the Civil 3D drawing to AutoCAD then export the parcels to the kml/kmz format.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
TerryDotson
All results are a reflection of the output driver (Civil3D) and the graphics target (GE).  Keep in mind that GE (unless changed recently) does not support linetypes.  That means the output driver would have to send out several short segments.  While that may look okay in GE it would be a mess on re-import of the content.
brian.strandberg
I assume you are using EXPORTKML in Civil 3d to export.
For the linetypes you can try this procedure outlined here: https://forums.autodesk.com/t5/autocad-map-3d-forum/exploding-a-linetype/td-p/5449063
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
