Export corridor solids - some links are missing?
martin.folber
Message 1 of 8
martin.folber
please is anybody able to explain the mystery, why only some links are offered in the corridor export solids dialog or also in Corridor.ExportSolids() API function?
We didnt find the key, how this command works. There should be "bodies" for each selected coded link, but most of them are missing...
Martin
Replies (7)
Message 2 of 8
sanith_parsi
Hey @martin.folber  there could be many reason
1- Links must form closed shapes between two regions.
2-Check the subassembly composer if your using the specific assembly to built the corridor ( check geometry defination)
3-Visualize in Section Editor:- to know if the links forming a complete, enclosed shape? If not, Civil 3D can’t generate the solid.
type this in command bar CorridorSolidsFeatureLinesReport  to check the detailed report.
Hope this link helps you as well
https://help.autodesk.com/view/CIV3D/2023/ENU/?guid=GUID-27BD6D2B-1F08-4616-8ED0-1C4F59D92BF9
Message 3 of 8
martin.folber
Hi @sanith_parsi,
I was writing about links => bodies, which are missing in dialog for Export Corridor Solids function. Shapes are not problems...
Message 4 of 8
sanith_parsi
@martin.folber can i have a screenshot to understand better ?
Message 5 of 8
martin.folber
Hi @sanith_parsi,
here is the screenshot
Message 6 of 8
sanith_parsi
Ok Martin,
Here are the things i can suggest
1-Try changing the frequency in the corridor settings and regenerate the corridor.
2-Use the Command ' Extract corridor Links'
3-Check the Link codes assigned for the corridor ( this might also be the issue )
All the best...
Message 7 of 8
martin.folber
Hi sanith,
thanks for your suggestion, but I think this is some internal bug or secret logic, how only some links are recognized for extraction...
Message 8 of 8
sanith_parsi
Ahhh my bad, Hope you find the solution.
Could you please post the solution when you find it.
Thanks and Happy Weekend
