Civil 3D Forum
Export Civil Objects to SDF
10 REPLIES 10
Message 1 of 11
dkaven
1381 Views, 10 Replies
dkaven
I've been looking a old posts and I have not seen anything to help me with this.
The problem is when using the "export civil objects to SDF, It will not export my civil 3D parcel objects.
I've tried it in 2018 and 2020. The command seems straight forwarded. It will create the the SDF file but will not have the civil object data. Looking at the command line after the file is created it states Command: _
AeccExportToSDF
Exported 0 points
Exported 0 alignments
Exported 0 parcels
Exported 0 pipes
Exported 0 structures
But in the dwg file I have civil 3d parcel objects.
Thank you for your time
Danny Kaven
AeccExportToSDF
Exported 0 points
Exported 0 parcels
Exported 0 pipes
Danny Kaven
10 REPLIES 10
Message 2 of 11
Wojtek_Garczewski
in reply to: dkaven
Wojtek_Garczewski
Hi @dkaven
Have you been able to resolve your query?
Otherwise, I would like to see how it would work on my end and check whenever I'm able to export your parcels. Is it possible to share your *.dwg file with us?
Let me know, please.
Wojtek.
Wojtek G.
Technical Support Specialist
Civil Engineering Solutions
Hi @dkaven
Wojtek.
Wojtek G.
Message 3 of 11
dkaven
in reply to: Wojtek_Garczewski
dkaven
I've been looking and working with this, and no luck yet. Basically I have a dwg made 2 Civil 3D parcels and ran the command "export civil objects to sdf".
I did narrow it down to my dwg. If I create a new dwg from an out of box dwt it will work. If I create a new dwg from my company design dwt it will not. I also ran audits etc to make sure it was a good dwg.
Please see attached dwg
Thank you for your response to this problem I'm having.
Danny Kaven
Danny Kaven
Message 4 of 11
Joe-Bouza
in reply to: dkaven
Joe-Bouza
I did a little experiment:
1. I created parcels from clean lines and export to sdf worked
2.I then added four more parcels created from polylines and sdf no longer worked
Joe Bouza
Joe Bouza
Message 5 of 11
rl_jackson
in reply to: dkaven
rl_jackson
SDF is for Map3D export, Civil objects while there in the same software don't export to SDF unless you explode them to dumb acad objects.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
Message 6 of 11
dkaven
in reply to: Joe-Bouza
dkaven
All my parcel have be created form objects "polylines". Yet it would work in out of box dwt but not my company design dwt. I'm going to try your test. Thank you Joe
Danny Kaven
Danny Kaven
Message 7 of 11
dkaven
in reply to: dkaven
dkaven
OK I ran the Export Civil Objects to SDF again. this time the parcel was created by the parcel tools, not from objects. still not luck.
Danny Kaven
Danny Kaven
Message 8 of 11
in reply to: dkaven
If you are Exporting Percel or other Civil Data to SDF ,  then using Civil 3D 2020, direct export Civil Object to SDF, It works for me, If you are Exporting Cad data like polyline , or polygon as MapExport commond to SDF , then make sure to select in option tab when exporting to sdf check  treat closed polyline as polygon.
Message 9 of 11
Wojtek_Garczewski
in reply to: dkaven
Wojtek_Garczewski
Hi @dkaven ,
Thanks for sharing your file and a very precise explanation of your workflow.
Per my investigation, it looks that the issue appears when in Parcel Style upon a Summary tab, Parcel Name Template value is set to <[Parcel Number]> only.
Once you add any Suffix or Prefix to it, or another property naming filed, or change it to a different one, it will export your parcels correctly. Please see:
Hence, I do not find an explanation why it doesn't work when Parcel Name Template is set up to <[Parcel Number]> only, I will log this to our development team to take a closer look.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Hi @dkaven ,
Wojtek
Wojtek G.
Message 10 of 11
dkaven
dkaven
Wow! That makes sense why it would work in out of the box. The out of box style is prefixed with a number. So I added a prefix to the current style I'm using and as you stated in the demo, and it worked.
Will the development team respond to this if we have a fix when using number only?
Nice work Wojtek!
Thank you so much,
Danny Kaven
Nice work Wojtek!
Thank you so much,
Danny Kaven
Message 11 of 11
Wojtek_Garczewski
in reply to: dkaven
Wojtek_Garczewski
Hi Danny,
Glad to hear it works on your end too.
As this is redirected to DevTeam, they will take action to look at it definitely. I can't promise on any dates, tho.
If you need any additional assistance just let me know and I will be happy to help.
Wojtek
Wojtek G.
Hi Danny,
Wojtek
Wojtek G.
Rail Community
