Export and Explode
Export and Explode
Automohan
Export and Explode
Automohan
Is both are same function "File Export to AutoCAD & the command explode in civil 3d
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Jowennl
I believe it is not the same function.
1) Export to AutoCAD - Allows you to save your Civil 3D drawing to new autocad file as exploded version without destroying your current Civil 3D drawing.
2) Explode - Explode command to your Civil 3D object like Corridor simply explode it and break your corridor as cad objects like lines or polylines.
I would recommend you using the first one if you wish to send cad copy of your Civil 3D drawing and use explode only if you need to explode. (Just be careful with explode) If unsure create back up of your drawing and test them.
Cheers,
Jowenn
